DT50 Head loudly hissing for amplifier models and L6 link
orbitus
I used to buy this amplifier, the transformer was repaired. Eleva has a base, but if a loud guitar game is concealed. This would be good to reduce if possible. But my bigger problem is that if I set up with DT Edit program, any amplifier model will be very loud for the hissing. POD HD500x is from L6 links via high hiss, but if I'm going to jack the amplifier, you do not. Cabinet simulations in the head can be used, they do not hiss. Now only Cabinet simulations are switched on and I use the 4 basic topology. Unfortunately, the benefits of L6 Link can not take advantage of ... something confused in the electronics? I tried reset. I reloaded the firmware. Did not help. I really like the sound and knowledge of the amplifier! I would like to continue to use (with L6 link)!
The problem is not with DT EDIT software, but on the digital-analog converter of the modeling in the amp head. There will be noisy. But the cabinet simulation is clear. L6 Link is modeling the software in the head, so noisy. Jack cable is modeling in POD HD500X, not noisy. Condenser can be a memory error ... I'll take it to a specialist.
