two powercab 112+
jankolle
I need help.
I have a helix and two powercab 112+.
I cnt figure out how to make a preset, with dual mono and two different amps goint to one powercab each. not even when i create two independent paths in helix, can i assign one amp to one powercab. it's driving me crazy
Try this and see if it works:
When using parallel paths, with one amp model on each path, grab hold of the point where they join back together and pull it down so there are two outputs on that path.  You can do it on path 1 or path 2.  Then change the outputs to send 1/2 for one and send 3/4 for the other.  Connect your cabs to those sends.
