Can EXP pedal raise and lower parameters at the same time?
brokenbones
Yup!  The Controller Assign feature does this easily. See Helix Floor Owner's Manual ver 3 - rev E PDF, Page 53, et seq.
Both parameters must be Controller Assigned to the same Expression Pedal.
For the parameter to be lowered, reverse the Min and Max value assignments, for example Min:75 and Max:25.
For the parameter to be increased, assig the Min and Max values you would normally desire.
Addendum:
rd2rk answered you first.
I got called away from the computer hahaha.
