wdejwdej
Snapshot selection
Hi guys.
I have a question that may be easy for experts to answer.
I work with 2 snapshots
A. 2 effects active
B. 3 effects active
If I have selected snapshot A, I sometimes manually activate a 3rd or 4th effect.
If I then go to snapshot B and later back to snapshot A, then 3 or 4 effects are active, while I would very much like to go back to the original state of 2 effects.
Anyone have an idea if and how this can be fixed?
It would make me happy if this is possible.
thanks for your attention!
Willem
https://line6.com/data/6/0a020a3f041b611d61cac763b/application/pdf/Helix 3.0 Owner's Manual - Rev F - English .pdf
In global settings, change the setting so your snapshots to be "discarded".  This is what you need.  I use that setting so that if i accidentally change the tap tempo or something and re-select the same snapshot, all the settings are back to what I saved them as.
"If you’ve changed "Global Settings > Preferences" > Snapshot Edits to “Discard,” you must save the preset before selecting a different snapshot; otherwise, any edits will be discarded! "
You are my Hero !! Thanks man !!
