Restoring a preset
TheDarkKnight1
The process of saving individual presets to your computer which cruison2 alluded to is called exporting.
In HX-Edit you will see two buttons at the top on the left sidebar called export.
You should familiarize yourself with those and learn the difference between them.
Once you have successfully exported your presets to the computer you can then import them back in the same way.
If you import a preset it will overwrite what is there.
Take some time reading up and learn to use your gear.  The temptation is to just go ahead and learn by doing but there is a whole lot of stuff you will likely never learn by accidentally coming across it.  You should do some studying.
I use 2 preset folders.  One acts as a backup of everything.  That way when I accidentally overwrite something, I have a backup folder with all my presets.
Also, I back up everything every single time I make a change.  If I need to restore specific presets, I can just restore from a backup into a free folder, and then copy from there.
In case you need just a single preset of a backup and didn't export it separately, do this:
- Backup the Helix.
- Load the backup containing the preset in question.
- Export the preset in question.
- Reload the backup you just created.
- Import the preset you've exported.
Et voila.
On 9/27/2021 at 8:54 AM, TheDarkKnight1 said:
Hi everyone,
I occasionally make the error of overwriting presets. Is there a way to restore a single preset from a backup?
You no longer have to mess around with restoring a prior backup or setlist and then exporting and importing, there is a better way available. If you have a prior backup (you probably have at least one from last time you upgraded the firmware) just do this:
  1. Using HX Edit click on 'File' --> 'Extract Files From Backup'
  2. Navigate to and select the backup you want to extract from and follow the prompts
  3. You should now have every preset in individual files from your backups, separated in directories named after your setlists. The backup utility will even prompt you when it completes and dump you in the master directory for the extracted presets.
  4. Back in HX Edit, highlight the slot you want to place your preset in, use the 'Import' function, and navigate to the file for the preset you want to restore.
The ease of use of the 'Extract Files From Backup' utility provides yet another great reason to make periodic backups.
2 hours ago, SaschaFranck said:
Cool. This escaped me. Not that I ever needed any such a function, but it's pretty good to know it's there. Has this been exisiting for longer already?
It's been around for a couple/few of the more recent firmware & HX Edit versions but sort of flying under the radar.  It had a few bugs when first released. They got fixed though and it really is handy.  One of the only things in HX Edit that works offline too.
I see. Quite strange that it's working offline, though. I mean, usually you'd want this functionality to actually get a patch back onto your device.
I would see retrieving a patch as the most likely scenario as well. I appreciate that they set it up for offline use though.  It doesn't require any data from your HX device; only a backup file from your local filesystem; so I guess they figured, why not?
Could also see it coming in handy perhaps in a scenario where your device is locking up and your last backup file is corrupt or not loading properly.  At least you might be able to get at your setlists and presets via an old backup and load them up piecemeal in an effort to recover as much as possible. Personally I was happy to see this come along because part of my firmware update process always used to be an export/backup of all my setlists and presets individually in addition to a full backup. This is considerably less hassle.
  • 2 months later...
This does not exist in the latest version of HX Edit I have. "Extract Files From Backup" is not an option in my file menu. I have the latest version of HX Edit.
Yes it does.
As noted by “PerS” in the post above - Page 28 in Hx Edit Pilot's Guide.
https://line6.com/data/6/0a020a3f137e660b4f6a285cb7/application/pdf/HX Edit 3.11 Pilot's Guide - English .pdf
Hope this helps/makes sense.
It is definitely there in HX Edit 3.11(currently the latest HX Edit version), as @Pers and @datacommando pointed out.  I would check under 'Help' --> 'About HX Edit' and ensure I was running HX Edit 3.11.
