danieles Posted October 10, 2021 Share Posted October 10, 2021 Do you know if there’s a way to have certain effects to be the same across presets, so if I change them in one preset, they are also changed in the others? Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 10, 2021 Share Posted October 10, 2021 No, no way to do that. What you can do is save a customized version of any FX block as a Favorite and use that copy when adding the FX block to a preset. But later changes must be made individually in each preset. Change the Favorite version first and then replace each of the existing blocks with the modified Favorite. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 11, 2021 Share Posted October 11, 2021 2 hours ago, danieles said: Do you know if there’s a way to have certain effects to be the same across presets, so if I change them in one preset, they are also changed in the others? Go to Ideascale, do a search, vote for every one of the suggestions made by users who didn't search first. 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted October 11, 2021 Share Posted October 11, 2021 One time when I discovered a more optimal setting for my amp, I had to update the amp block in every single preset (25 at the moment). Using copy/paste function in HX edit makes it slightly faster. I wish there was a way to have "global" blocks that can all be adjusted at the same time. This is not an option right now, unfortunately. Quote Link to comment Share on other sites More sharing options...
