Hotone Ampero Press Expression
denyrunner
Hi, I have the Hotone, very nice pedal but I can't make it work properly:
I have 2 exp pedal un a Y cable (TRS --> TS + TS): the boss exp pedal works great after some tweaking on the settings.
The hotone don't: it gets to 100 in toe position, 0 to middle and it sweeps back to 100 in heel position.
Any ideas ?
I'm living with that issue thanks to a very badly DIY workaround: a placed a cable under the heel position so that I can't go further than middle position :D
  • 8 months later...
Any ideas ?
Have you changed the global settings yet and does it work? I am thinking of getting this pedal
There really should be a “sticky” thread for this thing about expression pedals and Line 6 hardware. Check the date on these threads.
https://line6.com/support/topic/15999-external-expression-pedal-calibration/
Hope this helps/makes sense.j
  • 1 year later...
On 12/28/2023 at 3:49 PM, duc1000 said:
Did you find a solution @piepolitb? I have the same issue with my Hotone Ampero Press. Thx
Hi, I had the same problem with the new Hotone Ampero Press 2.  The solution is to use a TRS cable (stero cable with two black rings). I tried a Y cable with 1 TRS and 2 TR to use the button but it doesn't work, the expression pedal goes 0-100 (middle)-0
The problem with this is that I can not use the foot switch.
Edited by oscardrbcn
Adding more information
On 1/11/2024 at 1:12 PM, guig53 said:
No solution for AMPERO II PRESS with HX effects..  :(
It's a shame cause it's light compared to the Mission pedal.
Why? I think it has to work with a TRS cable. In HX Stomp works
I found IME that the "expression" pedel in Hx/Helix is just looking for a simple resistance sweep as a volume pedal does.  One side of a volume pot to ground. Anything labled "expression" doesnt not seem to work.
