Has any used an external generic valve preamp live with Helix?
Vulture1
I had a look around the forums, but can't see anything on this subject.......so what does anyone think or had experience of using an external valve preamp live? Here's the scenario/thought.........pretty normal stuff really, I go out of my Helix floor directly to our Behringer XR18 when I play live, and that's it - simple. What I'm wondering is, if going out to an external generic mic/line valve preamp (such as a Behringer T1953) in our PA rack before hitting the mixer would 'warm' up things a little. It may do nothing, but I wondered if anyone had tried this and if so if they felt it was worth it?
Having never used a tube amp, I can't speak to the allure.
But I can use a little deductive reasoning to figure this out ....
First, we must be aware that a modeler is not designed to give 'same room sound'. They mic'd a guitar amp. Modelers give that 'final sound', like you would hear on an album or through the pa at a concert. It isn't what you hear in your bedroom direct from your amp.
Once we know this, we can then say - adding the T will still not give you that bedroom sound.
However, let's take a look at how to use this thing anyhow (particularly since you aren't talking about your bedroom):
In the physical world, where would the tubes be? They would come after the preamp and before the cab.
So, we can assume that putting the T after the L6, which is after the preamp/amp/cab/mic, would not be the right placement.
This would mean, we would need to put the T in the fx loop.
I don't know if we can put the fx loop between the amp and cab, or between the cab and mic. But those would be the most ideal place to put it.
