Tremolo bar thread size
Sure you don't mean Variax 600? To my knowledge, the original Variax, later dubbed the '500' was only sold with one body style, and it was a hardtail.
And the 600, which did have a tremolo arm, had one that snapped into a collar and was stabilized with a tiny allen set screw. The bar, itself, didn't screw in.
Not sure how to help you on this one - don't see anything with a 5-6mm thread.
Hi C -
I bought the guitar used & was not familiar with how a whammy bar attached to a L.R. Baggs tremolo bridge. There is a set screw, but I also thought that I saw a few threads inside of the collet. I’ll investigate further for the appropriate bar.
Thanks for your input & have a good day.
Sid
Happy to try to help. There's still the question whether it's a 500 or a 600. I suppose it's possible that yours may have been modded. I've attached an image of my 600, showing the bridge & tremolo. The set screw has been replaced with a longer one. But the end of the bar inserted into the collar definitely is smooth, and rounded at the end. No threads at all...
Gotcha. I like the color combo of your 600.
I registered my Variax & the serial number came up as a Sunburst 500, so the bridge may have been modded by the original owner. I’ll see if I can mic the inner diameter of the collet with a caliper to get the exact bar width.
Thanks for the visual & the explanation - very helpful.
