The pickup of the thick sixth string does not work
AlfonsMallgan
I have a Line 6 Standard Variax-guitar which I bought from a private person some time ago. However, the battery driven pickup of the thick sixth string does not work. It does not catch the string vibrations. What to do? Try factory reset and/or firmware update? I live in Sweden.
It's not likely a software problem, so resetting, and/ or reflashing the firmware probably won't help.
You can try cleaning around/underneath each individual bridge saddle... the ground connection for the piezo saddles relies on solid contact with the bridge itself. If there's a bunch of accumulated dust and crud under there, then that connection can be interrupted. If that doesn't help, then that individual piezo is dead and will need to be replaced, and it's time for a service ticket.
  • 1 month later...
