3.15 Update-Tesselator and Ratchet Not Working
Corkenmahopper
Anyone else having issues with the Tesselator and Ratchet delays not working?  All other updates working fine.  These both are "off" when first selected.  When turned "on" they do not work, or respond to any of the parameter changes.
Thanks
You did do a factory reset after the update, didn’t you? It is a recommended part of the update procedure.
When stuff starts to behave in an unexpected way - perform a factory reset.
EDIT:
PLEASE READ THE RELEASE NOTES - BOTH OF THESE EFFECTS ARE BYPASSED BY DEFAULT
Hope this helps/makes sense.
Edited by datacommando
Added info
Just now, Corkenmahopper said:
Yes, sure did.  Factory reset, then restored the backup that was done prior to the update.
Yes, but the release notes explain how these 2 effects function, and they are off by default.
  • Upvote 2
