G10TII - red flashes when docked
wjoyce
I have a new G10TII and it constantly presents a flashing red LED when docked.  It flashes 4 times, then pauses.  I've chceked that it is fully-docked and undocking and redocking resolves it for a while (flashing green transmitter LED and white base LED), but it will eventually return to the 4 flashing red LEDs.
Any ideas.  The red flashing does seem to be some sort of error code, but I can't find what it means.
As soon as it does only flash red couple of times when just docked, is fine. Mine does the same. After that it should either flash green when charging, or solid green when fully charged.
Yeah, I don't think this standard behaviour.
I place the transmitter in dock, it flashes red briefly then turns solid green (or flash green if charging).  All appears normal.
At some point, it can be 5 minutes, sometimes a few hours, it'll start flashing red again, but it flashes in a distinctive pattern, not just on-off-on-off.  It flashes 4 times (approx 0.5 second each flash), then the LED is unlit for approx 4 seconds.  It'll continue flashing red like this until it's undocked and redocked, after which it'll reappear again.
  • 4 weeks later...
I seem to have the same problem. I sent one unit back to the retailer because of the issue. I have just received the replacement and the replacement has exactly the same issue. Will be contacting Line6, again...
I HAVE HAD THIS THING LESS THAN 6 MONTHS.
The G10 is an extremely poor design and ridiculously overpriced.
- Transmitter LED stopped glowing at all
- Transmitter would no longer charge.
- G10 Receiver base constantly pulsed red light.
- Power cable to the Receiver is loose and easily bendable.
- Collar around the G10 Transmitter broke a few weeks ago after barely touching on my leg while it was plugged into a Les Paul.
- Transmitter Cannot be fixed and must be replace - another $99!!
- Transmitter is in the way and awkward whether using it in a top jack (Strat style) or side jack (LP style).
- The G10 should come with a 90 degree dongle cable and strap attachment so it can be used like a Pro pack.
I have unplugged the G10 for the last time and thrown it away....which is how I modified my G10  :)
I will never buy another G10, and I do not recommend buying the Relay G10.  There are too many other wireless systems that do the same job for far less....search Amazon and pay $50 bucks for one that works and has a better design.
Bye G10.
