stevenah Posted February 17 Share Posted February 17 I've noticed a very big drop in volume when using the 2204 model. Is this a problem with the firmware? The drop in volume is so great that I can't use it in my user presets for playing live. Any suggestions? Quote Link to comment Share on other sites More sharing options...
olerabbit Posted February 20 Share Posted February 20 Hello stevenah, unfortunately the volume of the several amp models varies. For that reason some amp models are useless for me, too. It's difficult to help you from far. Idea: please find my settings attached, maybe it helps. I adjusted the cab volume but I use IR which offers more volume options. The stock cabs are all on 0 db - try to increase it. If you save the position of the volume pedal please make sure you saved it in the right position. Günter POD Go Brit 2204.pdf Quote Link to comment Share on other sites More sharing options...
voxman55 Posted February 20 Share Posted February 20 3 hours ago, olerabbit said: Hello stevenah, unfortunately the volume of the several amp models varies. For that reason some amp models are useless for me, too. It's difficult to help you from far. Idea: please find my settings attached, maybe it helps. I adjusted the cab volume but I use IR which offers more volume options. The stock cabs are all on 0 db - try to increase it. If you save the position of the volume pedal please make sure you saved it in the right position. Günter POD Go Brit 2204.pdf 661.89 kB · 7 downloads And if you are using an EQ, try placing it at the end of the signal chain or between the amp/cab rather than before the amp. Quote Link to comment Share on other sites More sharing options...
