yalyari Posted February 20, 2022 Share Posted February 20, 2022 I sometimes use HX Stomp as an audio interface, sending audio from PC to monitor speakers. In this usage I want to shut down the input signal path. As I understand Stomp disables input path if nothing is plugged in, but my setup has fixed connection to L/Mono, so this is not usable. Currently I put -120dB gain block to suppress any noise coming in. Is there any better way? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 20, 2022 Share Posted February 20, 2022 The attached template preset routes the processed signal to PathB, which goes to your DAW on Input 3/4. The Split prevents that signal from reaching the Main Outs, which receive the Output from the DAW. If you want to direct monitor the processed signal on a separate amp or FRFR just take the signal from the physical sends. VST Input3.hlx 3 Quote Link to comment Share on other sites More sharing options...
yalyari Posted February 21, 2022 Author Share Posted February 21, 2022 Nice! Far elegant than my brute force hack. Thanks a lot @rd2rk Quote Link to comment Share on other sites More sharing options...
