cbaten Posted February 22 Share Posted February 22 HXStomp XL 3.15 - I get a trigger for 'next snapshot' on both press and release of an external footswitch FS8 if I link the function 'snapshot up' to FS8 function through global settings. If I do this within a preset via the command center I can choose 'press and hold' and then press works as expected and gives next snapshot and I also can use the hold function for something else. But I do not want to set this manually in each and every preset again, I would like it to be set globally, as that is what I bought the footswitch for. Is there a way to set FS7 and FS8 globally to 'press and hold'? Or is there any other global solution? If not, then it would maybe be nice to add this choice to the FS7/8 assignment global menu in a next update? Cheers, Chris Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 23 Share Posted February 23 What footswitch are you using? Quote Link to comment Share on other sites More sharing options...
