reverendrambler Posted March 16 Share Posted March 16 I'm new to this so I should apologize before hand. I can't find any specific information regarding how to setup a vocal mic into the Helix LT, with a guitar. I was told it can be done, there's tons of forums and video related to this regarding impedance issues or for the Helix floor. If anyone could help, guide me to a resource of any kind it would be greatly appreciated. Can't find anything related to this in the manual as well. I admit Im a noob, what am I'm missing here. Please help, thanks!!! Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 17 Share Posted March 17 I’m a bit confused because your title say ‘…. w/mic’ but in your message you say ‘…with a guitar’. I’m going to assume you want to know how to set up your Helix LT so that you process both your guitar and a mic for vocals separately. Connect your guitar to the Guitar Input. Set Path 1 Input to Guitar. Connect your mic (dynamic, not condenser) to the 1/4” Return 1 input. Use an adapter if necessary. Set Path 2 Input to Return 1. Set the Return 1 Level to get a proper input level from the mic. Edit: There is no Level setting when you use Return 1 as an Input block. Add your desired processing blocks to each path and route the output(s) to your destination device(s). Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 18 Share Posted March 18 Also, I expect you’ll need to set Return 1 to Instrument level in Global Settings. Quote Link to comment Share on other sites More sharing options...
