HX Stomp XL + ENGL Fireball 100 4CM
djtschke
Hi All,
I have a problem regarding the integration of my HX Stomp XL into the FX Loop of my ENGL Fireball:
I connect using 4CM:
Guitar -> Stomp Input L / MONO -> Stomp Output L / MONO -> Fireball Input (Preamp) -> Fireball FX Send -> Stomp Return L / Mono -> Stomp Send -> Fireball FX Return -> Fireball Speaker Out -> Speaker
The Fireballs FX Loop Knop is turned fully to the right (100% Wet FX Loop). Noise Gate at 12 o'clock.
Now any time I try out an 4CM Preset of the stomp or create my own preset including an FX Loop block I get a high pitching continuous sound from my amp / box which does not sound healthy at all. It is really squeeling and not the typical noise. Sounds much more artifical an constant.
Would be very happy if you could help me with your experience as under the current described circumstances I cannot use the Stomp with the ENGL which really is a pitty.
Thank you so much!
Best regards,
Max
You have the connections a bit messed up. It should go ( —> = cable)
Guitar —> XL Guitar In
XL FX Send L —> Amp Input
Amp FX Send —> XL FX Return L
XL Main Out L —> Amp FX Return
  • 2 weeks later...
