BarkingSpiders Posted March 28, 2022 Share Posted March 28, 2022 I am experiencing lots of crashes with the POD Go ASIO driver in Windows using Ableton Live 11. Recording goes fine until you switch off the power of the POD Go. That will almost always result in a fatal blue screen of death. So I'm suspecting a driver fault. Does anyone else have similar problems? 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 28, 2022 Share Posted March 28, 2022 Are you switching the POD Go off while Abelton is running? If so, try closing Ableton before you turn off the POD Go. Quote Link to comment Share on other sites More sharing options...
chugzilla Posted March 28, 2022 Share Posted March 28, 2022 mine does that when i unplug the usb using cakewalk with windows 10 or 11....i get that screen and pc restarts...so i have learned dont unplug anymore lol...when daw is open 1 Quote Link to comment Share on other sites More sharing options...
BarkingSpiders Posted March 28, 2022 Author Share Posted March 28, 2022 Yes I unplug it while it is running. Probably not ideal, but it sure shouldn't cause a system crash :) Is this bug known to the dev team? Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 28, 2022 Share Posted March 28, 2022 If your computer does not crash when you close the Ableton program before turning off the POD Go, then clearly that’s a simple way to avoid the crash. As for the cause and a solution you may be right that the problem is the Line 6 driver. I would open a support ticket with Line 6. It could also be a Windows problem, or an Ableton problem, or a conflict with one of any other usb device drivers on your system. You should also explore those possibilities if you really want a fix. Personally, I would just avoid the problem. 1 Quote Link to comment Share on other sites More sharing options...
px920906 Posted March 29, 2022 Share Posted March 29, 2022 same here with studio one. also I can't turn the computer into hibernate mode with the daw & pod go running, otherwise BSOD when wake up. same applies to hx stomp... my another usb audio interface works fine though. 1 Quote Link to comment Share on other sites More sharing options...
spaceatl Posted March 30, 2022 Share Posted March 30, 2022 I have a 12 year old VAIO I use for the HX most of the time. Turning off power management did the trick for me. Another way to approach this is to create a DAW hardware profile. You can actually do quite a bit to optimize your Windows computer for DAW use. Often, power management on the USB controller can cause problems when the device is in streaming mode. The meaning is the driver is not likely complying with power management rules and not shutting down clean...Outside of tweaking the power profile, you can shut down services that are not needed (anti-virus, NIC, swap file settings, etc...). It's a bit of a pain rebooting into a DAW profile, but I find it makes for stable sessions on windows on a multi-use machine...Line 6 isn't the only vendor with problems in their power management implementation.... 1 1 Quote Link to comment Share on other sites More sharing options...
BarkingSpiders Posted April 1, 2022 Author Share Posted April 1, 2022 On 3/29/2022 at 6:22 PM, px920906 said: same here with studio one. also I can't turn the computer into hibernate mode with the daw & pod go running, otherwise BSOD when wake up. same applies to hx stomp... my another usb audio interface works fine though. This is what I noticed too. It's not just unplugging it; it is also setting my computer to sleep which might cause the crash. In any case: I opened a ticket at the Line 6 support team and hopefully they are able to relay this to the dev team. Quote Link to comment Share on other sites More sharing options...
