JWinstrand Posted March 29 Share Posted March 29 firmware 3.15 helix floor problem... when i add a wah to my preset the toe switch will only work while the usb cable is plugged into the unit. grrrrrrrr! any help would be appreciated Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted March 29 Share Posted March 29 Post this in the Helix forum, otherwise you'll be waiting until 2 years after the second coming for anybody to see it. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 1 Share Posted April 1 On 3/28/2022 at 8:02 PM, JWinstrand said: firmware 3.15 helix floor problem... when i add a wah to my preset the toe switch will only work while the usb cable is plugged into the unit. grrrrrrrr! any help would be appreciated Another user had a similar problem recently with the toe switch not working after upgrade to 3.15. He got it to work again by doing a backup, factory reset (press FS9 & FS10 on the Helix while restarting), and then restore your backup. Also make sure no cable is plugged into your EXP 2 input. 1 Quote Link to comment Share on other sites More sharing options...
