alancraig Posted April 4 Share Posted April 4 Hello - I've only had the Pod go for a few weeks, so I'm still figuring out a lot of things. While I've been able dial in some really nice and convincing tube overdrives, I'm struggling more with clean tones. Specifically, I'd like to dial in a good bright clean country strat (2nd position) sound. I may be approaching it incorrectly, but I'm missing the mark so far. Any suggestions? Quote Link to comment Share on other sites More sharing options...
olerabbit Posted April 6 Share Posted April 6 Any sound is a matter of taste. And a matter of speaker frequencies. Difficult to suggest. What sounds good with my rig can sound less good with yours. For the start: here are some „analog“ tipps which might be an inspiration for your search: https://www.guitarworld.com/gear/how-get-true-country-guitar-sound. I would check out the Fender models trying out all the cab sims. Depending on your guitar's sound you can check them out. A lot of work I know but I had good results this way. I personally like and play the Archetype Clean (PRS Archon Clean Channel) which sounds really good with my PRS guitar. And a slight Minotaur distortion. I use the amp sim with a Divided By 13 cab IR from Vallahir. I bought a wav-file package directly from them - among other things including 62 RAW IRs which I all tried out. Yes,I did. Valhallir calls this package "V2 Rocky". Quote Link to comment Share on other sites More sharing options...
Elliott1921 Posted April 18 Share Posted April 18 Start with the Red Squeeze (sens around 6 and no level boost) into USDeluxeNrm (=Fender Twin) (drive around 4) into Adriatic Delay (=Boss DM+) with short delay time and low feedback (for a slapback) into any one of the reverbs (but I use a TC Electronics Hall of Fame in the Effects Loop at the end of my chain). Let us know if this helps! Quote Link to comment Share on other sites More sharing options...
