pipelineaudio1 Posted April 29, 2022 Share Posted April 29, 2022 anyone seen this? When copying presets, the values of certain parameters are changing on their own and then further breaking previously working snapshots with new values. Video included https://youtu.be/iPZxSZi_sw0 Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 29, 2022 Share Posted April 29, 2022 I was having some issues with strange snapshot parameters behaviour a few weeks ago. A factory reset solved it. Make sure you back up appropriately first. 1 1 Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted April 29, 2022 Author Share Posted April 29, 2022 I'll give that a try thanks! Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted April 29, 2022 Author Share Posted April 29, 2022 Is that hold down switches 9-10? Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted April 29, 2022 Author Share Posted April 29, 2022 Ok just did this, now it makes even the ones that were working before break Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted April 29, 2022 Author Share Posted April 29, 2022 Gonna give downgrading to 3.11 a try 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 30, 2022 Share Posted April 30, 2022 On 4/29/2022 at 8:00 PM, pipelineaudio1 said: Is that hold down switches 9-10? Reset Options Helix Floor/LT Button Combination Description 2 LED light Fun 3 & 4 Test Mode 5 & 6 Global reset 7 & 8 Reset setlists to factory, Keep IRs 8 & 9 Reset setlists to factory, Clear IRs 9 & 10 Reset setlists to factory, Global reset, Clear IRs 10 & 11 Upgrades existing presets to latest format 11 & 12 Clear current preset 5 & 12 Clear setlists, clear IRs, Return system settings to default 6 & 12 Safe boot mode To use Reset Options: Power off the Helix Hold the desired button combination Power on the Helix Release the button combination Please note: Buttons are numbered from top left to bottom right. 1 Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted April 30, 2022 Author Share Posted April 30, 2022 Again though please, is the one they mean the one where you hold down 9 and 10? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 30, 2022 Share Posted April 30, 2022 For me it was just the Global Reset, holding down 5 & 6 when restarting. Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted May 2, 2022 Author Share Posted May 2, 2022 None of these resets changed the behavior and I saw at TGP that others had the same issues. I sent in a ticket and a video and some repros, hopefully they can fix this Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 2, 2022 Share Posted May 2, 2022 On 4/29/2022 at 6:02 PM, pipelineaudio1 said: Gonna give downgrading to 3.11 a try If you haven't already, try the following before reverting back to 3.11. Did you also do a backup before doing the factory reset and then restore the backup afterwards? The backup restore is also part of the firmware upgrade process. Make sure to restart your Helix after the restore and ensure they have completed the rebuild process. 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 4, 2022 Share Posted May 4, 2022 On 4/29/2022 at 5:16 AM, pipelineaudio1 said: anyone seen this? When copying presets, the values of certain parameters are changing on their own and then further breaking previously working snapshots with new values. Video included https://youtu.be/iPZxSZi_sw0 On 4/29/2022 at 9:09 PM, pipelineaudio1 said: Again though please, is the one they mean the one where you hold down 9 and 10? I would go for the full factory reset (9&10 on the Helix) and then a restore, given the issue you are experiencing. Make sure you have a backup first. You may even want to consider restoring the backup that was created when you first did the 3.15 firmware update, in the event that any corruption or unwanted changes have occurred in your presets since then. 1 1 Quote Link to comment Share on other sites More sharing options...
premiermusic Posted February 2 Share Posted February 2 Anyone seeing this on Helix Floor units recently updated to 3.5? I work for a conservatory that has 6-8 Helixes (Floor and LT) and in prepping for a show this week we started having this happen even though we were on FM3.5 with all of the units. I'm going to try a global restore when I get in today on at least one of them and see if that helps but I was curious if this was still a thing. I'm being told that the same thing happened last year before I worked in the conservatory. Quote Link to comment Share on other sites More sharing options...
chrisguse Posted April 28 Share Posted April 28 I can confirm that I have experienced this behavior with 3.5. I've spent hours trying to track down specific conditions this happens without luck. For me the most consistent issue is the mix parameter of Elephant Man being set to either 100% or 0% in snapshots following a copy/paste from one setlist to another. The mix value for a snapshot in the preset I am copying from will be 20-50% or so and after the paste will turn up at 100% or 0%. I have experienced the issue with other blocks and other parameters, but not nearly as common. In my workflow, I use one preset per song in full snapshot mode and copy all the presets from a "master" set list to a show specific set list. It about 80 presets at a crack. All done in HX Edit. The result is that I need to test every preset that features Elephant Man prior to each show, which is quite tiresome as it is one of my favorite effects. Until today, I have been unable to find anyone else having this issue. What I haven't tried to do (embarrassingly enough) is export the "master" setlist and import it into a new setlist bank. I'm hoping that solves the problem and will see what happens next time I'm near my unit, but in any case it's a nasty bug (unless I'm missing something about how things are designed to work). Quote Link to comment Share on other sites More sharing options...
cglaser68 Posted May 2 Share Posted May 2 Have you tried exporting the individual patches (as opposed to exporting the setlist) and then importing each patch you need for the gig instead of a copy paste? I'd be curious to see if importing the patch prevents the parameter changing. At least then you'd have a workaround. You'd have to export all your patches once and then remember to export a patch anytime you make a change, but then before a gig you could just do an import instead of copy/paste. More work I realize, but hopefully not overly burdensome. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 2 Share Posted May 2 Also, a good idea when you copy and paste presets (or even import them) to restart the Helix before editing those presets as sometimes the presets will go through a rebuild process upon restart, unless this behavior has changed in 3.60. Not sure if this has any impact on errant parameter changes but it can't hurt as a preventative measure. Quote Link to comment Share on other sites More sharing options...
