HX Effects won't boot/turn on anymore...
kurtcobainfan
I recently updated my HX effects unit to the newest firmware update, (3.15 I believe) but it won't turn on anymore... (Had to find that out during rehearsal...)
It did turn on once or twice since I updated it, so I'm not sure if that's the problem. (But I did find it strange)
The power supply still seems to give power, so that can't be it.
Bought the unit secondhand, and since I'm located in the Netherlands, I don't think sending it back to Line 6 will be an option for me...  : (
You say the power supply still functions, therefore it could well be a hardware failure in the HX FX. The usual suggestion for trying to fix things is a Factory Reset to try to blow the bugs out, but if you can’t get it to power up then you really are stuck. (Factory Reset - Hold down FS6 and TAP while turning the power on.)
As your unit is pre-owned it is probably out of warranty, but you could still try to have it repaired by the official Line 6 -Yamaha Guitar Group service centre in the Netherlands.
HANEX
Waaier 36
VW Leimuiden, 2451
Phone: +31172506993
Email: info@hanexservice.nl
URL:
http://www.hanexservice.nl
Also one in Germany
PMS Electronics GmbH
Große Heide 27
Minden, 32425
Phone: +49571646000
Email: info@pms.de
URL: http://www.pms.de
I know that Bax Netherlands and Thomann are Line 6 dealers/distributors, so you could contact them to see if they can help you.
https://www.bax-shop.nl
https://www.thomann.de/nl/compinfo_contact.html
Veel geluk
Hope this helps/makes sense.
