Pod Go on Catalyst's power amp jack
shane66
Hello everyone, I own the Line 6 Pod Go and wanted to know if I should leave the cabinet simulation on when I plug the Pod Go into the Catalyst's power In jack ?
Thanks in advance for the answer !
Shane
There’s no right or wrong answer here. Experiment and go with whatever sounds best to you. The traditional setup would be to turn the cab sim off in your POD Go preset.
  • Upvote 2
Also consider that if you leave the cab sim ON and you're using the XLR Out on the Catalyst for FOH, you're now sending 2 cab sims to FOH, as it can't be turned OFF on the Cat. What's THAT gonna sound like?
  • Thanks 1
