Oddball89 Posted May 6 Share Posted May 6 Hi All, First time writing on this forum. Apologies if this has been addressed before, but I've spent a couple of hours trying to figure this out and can't. I have an HX Effects 3.15. I learned about the command centre today and thought, excellent! For a particular song I want to be able to press a footswitch and Snapshot 2 engages, and when I release the footswitch, it goes back to what it was – Snapshot 1 say. To do some fills with a octaver on, briefly. I can't for the life of me get it to work. I will get 'SNAPSHOT 2' appear on footswitch 6 in Stomp Mode, but it doesn't work how I want it to - it works like a stomp box, press once for on, press again for off (and that is certainly not what I've put in the command centre). I have set it up exactly how I was directed on the Steve Sterlacci video. It won't work in either Snapshot mode, nor in Stomp mode. I'm wondering if this is a known bug. Does anyone know what might be up? Kind reagards to you all. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 7 Share Posted May 7 On 5/6/2022 at 3:07 PM, Oddball89 said: Hi All, First time writing on this forum. Apologies if this has been addressed before, but I've spent a couple of hours trying to figure this out and can't. I have an HX Effects 3.15. I learned about the command centre today and thought, excellent! For a particular song I want to be able to press a footswitch and Snapshot 2 engages, and when I release the footswitch, it goes back to what it was – Snapshot 1 say. To do some fills with a octaver on, briefly. I can't for the life of me get it to work. I will get 'SNAPSHOT 2' appear on footswitch 6 in Stomp Mode, but it doesn't work how I want it to - it works like a stomp box, press once for on, press again for off (and that is certainly not what I've put in the command centre). I have set it up exactly how I was directed on the Steve Sterlacci video. It won't work in either Snapshot mode, nor in Stomp mode. I'm wondering if this is a known bug. Does anyone know what might be up? Kind reagards to you all. Quote Link to comment Share on other sites More sharing options...
Oddball89 Posted May 7 Author Share Posted May 7 Hi Rd2rk, This is exactly what I've done and it simply doesn't work. This is why I'm wondering if it's a bug. I'm using 4 cable method, does that make a difference? Thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 7 Share Posted May 7 It has to be saved that way in BOTH snapshots, else the values in Snapshot2 default to "NEXT". 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 9 Share Posted May 9 On 5/6/2022 at 4:07 PM, Oddball89 said: I have set it up exactly how I was directed on the Steve Sterlacci video. Just an educated guess, but I suspect that video was created with an earlier firmware version than 3.15. Before 3.15, Snapshots commands applied in Command Centre applied to EVERY snapshot... one setting regardless of which snapshot was chosen. In 3.15.... you can change the values on each snapshot. It's really powerful, but it has created confusion. On 5/7/2022 at 8:56 AM, rd2rk said: It has to be saved that way in BOTH snapshots, else the values in Snapshot2 default to "NEXT". ^^^ THIS ^^^ is what you need to do, and it "should" work fine :) Quote Link to comment Share on other sites More sharing options...
