Treering Posted May 11, 2022 Share Posted May 11, 2022 Do I need to have the power supply connected to the POD GO before I connect to the computer and turn it on? Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 11, 2022 Share Posted May 11, 2022 The POD Go won’t be powered by the USB connection, if that’s what you’re asking. Yes, you need to have the power supply connected. Quote Link to comment Share on other sites More sharing options...
Treering Posted May 13, 2022 Author Share Posted May 13, 2022 Will I need a Win driver to connect the pedal and edit software or will it work just by connecting? Quote Link to comment Share on other sites More sharing options...
grdGo33 Posted May 14, 2022 Share Posted May 14, 2022 The Pod Go will work on its own but yeah if you wan to interact with it from a PC you'll need to install software; https://line6.com/software/ Quote Link to comment Share on other sites More sharing options...
Robby66 Posted May 15, 2022 Share Posted May 15, 2022 Hi folks, I can't use pod go edit software. I'd installed necessery drivers (Line6 Driver2 Pod Go / Line6 Win USB). But the HP Notebook (Windos10) doesn't recognize the running unit at the USB port. Therefore the edit software dosen't recognize the Pod Go unit too. Any suggestions, please? Quote Link to comment Share on other sites More sharing options...
spaceatl Posted May 15, 2022 Share Posted May 15, 2022 Have you checked your BIOS to see if the USB port is configurable? Might have a legacy mode switch or something... Quote Link to comment Share on other sites More sharing options...
Robby66 Posted June 7, 2022 Share Posted June 7, 2022 Thx for all your hints. But me and my friend tried hard to connect the PG to computer without success. My friend owned the PG earlier and has had connected the device successfully before. But now he isn't able to do so too. It seems that the PG USB port isn't able anymore to detect and connect the PG with any Computer anymore. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted June 10, 2022 Share Posted June 10, 2022 On 6/7/2022 at 2:38 PM, Robby66 said: Thx for all your hints. But me and my friend tried hard to connect the PG to computer without success. My friend owned the PG earlier and has had connected the device successfully before. But now he isn't able to do so too. It seems that the PG USB port isn't able anymore to detect and connect the PG with any Computer anymore. Assuming you are on Pod Go v1.30 have you installed Pod Go Edit v1.30 on your computer? Quote Link to comment Share on other sites More sharing options...
