Guido_59 Posted May 29 Share Posted May 29 Hello I have bought an acoustic guitar after long time Epiphone EL-00 pro with has a Fishman Sonitone +sonicore , but I want change it with Seymou Duncan Mag Mic magnetic +condenser. To create good preset for a good sound have you some suggest? Don’ exist an acoustic amp, so what you use ? Do you use acoustic ir like 3sigma? thanks in advance? Quote Link to comment Share on other sites More sharing options...
lou-kash Posted May 29 Share Posted May 29 On 5/29/2022 at 9:14 AM, Guido_59 said: Don’ exist an acoustic amp, so what you use ? Whatever sounds good to me. I play an old Aria acoustic in open G, mostly with slide, via Seymour Duncan Woody single coil pickup, into a small 15W Squire transistor amp, sometimes into a Fender Blues DeLuxe (1994). Usually a compressor and the parametric EQ will do the job on the HX Stomp, same as with my analog effects previously. In fact, usually I also plug in my self-made stomp box plank – a bass drum substitute – using the HX Stomp as a 2-channel mixer. If I need it to sound more gritty without going into the "real life" amp, i.e. when recording or going directly into PA, I take something like the US Small Tweed block a.k.a. Fender Champ. (As you may have guessed by now, what I play on the acoustic is probably quite close to the blues…) Quote Link to comment Share on other sites More sharing options...
Guido_59 Posted May 31 Author Share Posted May 31 Thanks lou-cash! I play blues me too, anf aoustic jazz, so I'm oriented to Seymour Duncan Mag mic. Have you tried this pick-up? Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 31 Share Posted May 31 On 5/29/2022 at 8:14 AM, Guido_59 said: Hello I have bought an acoustic guitar after long time Epiphone EL-00 pro with has a Fishman Sonitone +sonicore , but I want change it with Seymou Duncan Mag Mic magnetic +condenser. To create good preset for a good sound have you some suggest? Don’ exist an acoustic amp, so what you use ? Do you use acoustic ir like 3sigma? thanks in advance? Hi Guido, You might want to investigate using the Studio Tube Preamp (based on a Requisite Y7 mic preamp), also an EQ block. Then add a LA Studio Compressor, chorus, delay and dynamic reverb. That should give you a place to start. You can add an acoustic guitar IR if you wish - try it and see how this works for you. I have used this setup for recording with my Fishman Rare Earth Blend equipped acoustic (one path for the pickup and the other for the mic), and another guitar with a K&K Pure (internal contact transducer) system. It is also the starting point for when I am only using condenser mics. You will need to mess around to get it how it suits you, and works with your instrument(s). There are many Helix/HX owners using acoustic guitars and getting great results. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
lou-kash Posted May 31 Share Posted May 31 On 5/31/2022 at 11:10 AM, Guido_59 said: Seymour Duncan Mag mic. Have you tried this pick-up? I've seen it but it was above my budget. Whereas the Woody SC was exactly what I needed: simple, flexible, robust, great value for the price. But I also have a Schertler Basik mic (discontinued) which can be put as a pickup onto virtually anything, even on a chair, a plank, you name it… On 5/31/2022 at 12:11 PM, datacommando said: You might want to investigate using the Studio Tube Preamp (based on a Requisite Y7 mic preamp) In the beginning I was using it for a while, but eventually I found that its effect on the overall sound is negligible, and thus a waste of a valuable block in the Stomp path. Hence I rather use a regular tube guitar amp modeller because it gives me more sound options. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 31 Share Posted May 31 On 5/31/2022 at 8:32 PM, lou-kash said: In the beginning I was using it for a while, but eventually I found that its effect on the overall sound is negligible, and thus a waste of a valuable block in the Stomp path. Hence I rather use a regular tube guitar amp modeller because it gives me more sound options. Hi, When it comes to this sort of thing everyone has to go with what works for them - as usual, where the Helix family of products is involved, there are no rules. Just go with the flow. :-) 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted June 1 Share Posted June 1 On 5/31/2022 at 3:11 AM, datacommando said: <Snip> You might want to investigate using the Studio Tube Preamp (based on a Requisite Y7 mic preamp), also an EQ block. Then add a LA Studio Compressor, chorus, delay and dynamic reverb. That should give you a place to start. You can add an acoustic guitar IR if you wish - try it and see how this works for you.<Snip> Absolutely a great place to start!! 1 Quote Link to comment Share on other sites More sharing options...
