ashton82 Posted June 14, 2022 Share Posted June 14, 2022 so when I use the 4 x cable method I have been told I need to disable (turn off) the amp and cab because I am patch into one, correct? Also do I always have to enable the "mono fx loop" in order for the presets to work in this setup? kr, A Quote Link to comment Share on other sites More sharing options...
rarellano Posted June 16, 2022 Share Posted June 16, 2022 Cab, yes, you must to turn it off. And amp, you could use it like a booster or overdrive in order to your imagination and the place you going to put the fx loop in POD Go chain. And yes, you must to always enable fx loop to use 4CM (four cable method). Quote Link to comment Share on other sites More sharing options...
