raulgranada Posted June 18, 2022 Share Posted June 18, 2022 how to connect an external wah pedal to pod go? thanks Quote Link to comment Share on other sites More sharing options...
NBell Posted June 21, 2022 Share Posted June 21, 2022 Hi raulgranada, There's ultimately two ways you could connect your external wah to POD GO. 1) You can always run your external wah before POD Go (Guitar > External Wah > Guitar In of POD Go) this would obviously place your wah before all blocks in POD Go. 2) Alternatively, you can connect your external wah through POD Go's FX Loop with the option to move the effects loop block to the beginning (or anywhere) of your signal chain, this connection would require two cables connected from your wah to POD Go's FX Loop: Connect the first cable from POD Go's FX Loop Send to your wahs Input, then connect the second cable from your wahs output to POD Go's FX Loop Return. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted June 21, 2022 Share Posted June 21, 2022 On 6/21/2022 at 2:41 AM, NBell said: Hi raulgranada, There's ultimately two ways you could connect your external wah to POD GO. 1) You can always run your external wah before POD Go (Guitar > External Wah > Guitar In of POD Go) this would obviously place your wah before all blocks in POD Go. 2) Alternatively, you can connect your external wah through POD Go's FX Loop with the option to move the effects loop block to the beginning (or anywhere) of your signal chain, this connection would require two cables connected from your wah to POD Go's FX Loop: Connect the first cable from POD Go's FX Loop Send to your wahs Input, then connect the second cable from your wahs output to POD Go's FX Loop Return. Agreed - but generally to sound better you'll want a wah at the front of your signal chain. 1 Quote Link to comment Share on other sites More sharing options...
