HX EFFECTS - Error -8212 on HX Edit - FW 3.15
defactobassplayr
Hello Line 6 Collaborative Community!
Got an HX EFFECTS
Windows 10 64bit
32Gbs RAM
Last June 2021 I, tried to use FX Edit - but kept getting error -8212. Wouldn't load the patches to edit - I could see the patch names though...
Support said to upgrade FW to 2.82? but couldn't get HX Updater to back up my patches - kept having errors. I did it anyway... Still couldn't get HX Edit to load my patches - same error -8212.
Support said I needed to factory reset my system.
Didn't have the heart to lose my patches, so I left it alone.
Tried again this week (June 2022) - same problem, but I upgraded the FW to 3.15 - same -8212 error code
Decided to bite the bullet and reset the system to factory (Power On+ FS6 + Tuner) - watched it reset and watched my patches GO BYE BYE
STILL GOT THE SAME ERROR -8212
Any ideas or solutions that other folks have found?
Thanks in advance
Update to HX Edit v3.15.
In HX Edit, lower left corner, there's a ? . Click that. Click ABOUT. You can now see BOTH the Device's FW version AND the HX Edit version.
They need to match.
FYI - the UPDATER only updates the FW. It does NOT update HX Edit, nor is it used to backup presets. You use HX Edit for that.
EDIT: When updating the FW be sure to follow ALL of the directions EXACTLY!
