Helix & Powercab 212 - So much boom/muffle
chris050177
Hi guys, hope you can offer some advice and help.
I have got a helix and PC212 hooked up via L6 link, set up the levels so presets turn yellow.
However every amp I try sounds so boomy, it’s crazy! I have an EMG loaded guitar so have turned the Pad On and not made much diff, is there something in general settings on Helix / PC that I’m missing? (Using the speakers rather than FrFr although still the same).
I have tried downloading some presets, ones built in and starting one from scratch with just an amp?
Any ideas lovely Helix users :-)
Have you tried setting the Powercab on an amp stand or a chair? Doing so will significantly reduce it's physical contact and acoustic coupling to the floor. Keeping it away from a rear/side wall or corner will also reduce acoustic coupling.
  • Upvote 2
+1 for the stand. I keep them just a tad under ear level and that's bringing back some brightness, but in general they also like some EQ to de-mud the response.
Also you can try the LOW cut on the back.
  • Upvote 2
Acoustic coupling to the floor can be a massive factor when the cab is on any floor other than a concrete floor. The way the majority of framed wood construction floors resonate will typically negatively alter the resulting sound.
  • Upvote 2
