HELIX RACK - MIDI SWITCHING - LOGIC PRO ISSUE
lucas_epidemic
MIDI Channel switching help!
Hey all, I'm trying to program channel switches and effects automation within patches from logic Pro X to the helix. All seems to be working fine other than when I pause playback on Logic.
Ideally when playback is paused and the locator is moved in logic no further midi signals should be sent to the helix but it seems that when I pause the playback the last midi signal is re-sent.
Set up it pretty much identical to this video and it seems that the user who made this video along with a few people in the comments have had the same issue.
Issue is visible in this video from 8:05 > 8:12:
Playback running > Midi switching turns off a block in the setting
Playback paused > Block that was just turned off by midi turns on again
Is anyone using logic Pro X to trigger midi switching and has a fix or can give some advice to a mid newby?
Thanks in advance
