oobboo Posted August 31, 2022 Share Posted August 31, 2022 Hello community, I have been having sporadic crashes on my HX Stomp for some time now. While I can still play guitar and hear something, but the complete UI is frozen. Also the footswitches no longer work. After a restart it behaves normally again. It happens every now and then, I can't see any regularity, still it's concerning and I wanted to check with you guys. I use the original power supply. I no longer have a warranty, the device is something about three years old. I hope you can help me. Greetings Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 31, 2022 Share Posted August 31, 2022 On 8/31/2022 at 7:57 AM, oobboo said: Hello community, I have been having sporadic crashes on my HX Stomp for some time now. While I can still play guitar and hear something, but the complete UI is frozen. Also the footswitches no longer work. After a restart it behaves normally again. It happens every now and then, I can't see any regularity, still it's concerning and I wanted to check with you guys. I use the original power supply. I no longer have a warranty, the device is something about three years old. I hope you can help me. Greetings Hi, When weird and unexpected stuff happens - try a factory reset - and if that doesn’t clear the bug, try a reinstall of the latest firmware. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
oobboo Posted September 1, 2022 Author Share Posted September 1, 2022 Thanks. How do I reinstall the FW? Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 1, 2022 Share Posted September 1, 2022 Go to the Downloads area of this website (see tab at top of this page). Select HX Edit in the Software (middle) field. Download the latest version v3.15. Run the downloaded file and install all components. Then run the HX Edit program with your HX Stomp connected. Follow the instructions. 1 Quote Link to comment Share on other sites More sharing options...
