lavalampguy Posted September 11, 2022 Share Posted September 11, 2022 A friend gave me this device recently, telling me he couldn't figure it out. Problem is, my new computer only has USB-C ports (and 1 HDMI port). The POD HD only has a USB port... so assuming I'll need an adapter of some sort? Also... did I understand correctly that Line 6 is no longer updating Monkey for anything MacOS-related? Thanks much! Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted October 9, 2022 Share Posted October 9, 2022 On 9/11/2022 at 12:29 AM, lavalampguy said: A friend gave me this device recently, telling me he couldn't figure it out. Problem is, my new computer only has USB-C ports (and 1 HDMI port). The POD HD only has a USB port... so assuming I'll need an adapter of some sort? Also... did I understand correctly that Line 6 is no longer updating Monkey for anything MacOS-related? Thanks much! You would need a USB-C to USB-A to connect to your Mac. If you want to use the HD edit software there are a few hoops you have to go through to get it to work. See here for that: https://line6.com/support/page/kb/general-faq/operating-system-information/apple-silicon-m1-or-greater-driver-installationremoval-notes-r991/. Using the POD HD as an interface for audio into a DAW I've found it's not stable at the moment. Check if the new driver works as one was released Sept of 2022. Jd Quote Link to comment Share on other sites More sharing options...
