Aux send stereo; what cable?
mcvmcv
On 9/20/2022 at 9:09 PM, mcvmcv said:
what kind of cable do i need to use the "send" in stereo to my mixer?
i split my signal using a ir to the send out to my mixer but want to go stereo.
please advise.
It would help to know what HX product you are wanting to “Send” from?
For example:
Helix floor and Rack units each have 4 x 1/4” mono Send jack sockets
Helix LT use 2 x 1/4” mono Send jack sockets
HX Stomp and Stomp XL both use a 1/4” stereo Send jack socket.
HX Effects uses 2 x 1/4” mono Send jack sockets
Then on your mixer input - are the inputs 1/4” Mono, XLRs, or does it have a dedicated stereo 1/4” insert?
Anyhow, if you connecting 1/4” Mono pairs to Mono (TR to TR)in then regular guitar cables will suffice - you know what they look like.
If it is Stereo out to 2x Mono in you need a TRS to 2x Mono TR cable. Likewise, if the Sends are going to XLR you will need a similar cable - Stereo TRS to 2x XLR, or 2x Mono TR to 2x XLR.
Some examples:
https://www.amazon.com/DISINO-Microphone-Unbalanced-Interconnect-Dynamic/dp/B083P6S976/ref=sr_1_2?crid=2C8JFPJTH4BJ8&keywords=TR+1%2F4+Jack+to+XLR&qid=1663713768&sprefix=tr+1%2F4+jack+to+xlr%2Caps%2C227&sr=8-2
https://www.amazon.com/DISINO-Y-Splitter-Unbalanced-Quarter-Adapter/dp/B083QKRNVC/ref=sr_1_18?crid=1KS49KKFG3HR0&keywords=TRS+1%2F4+Jack+to+2X+XLR&qid=1663713854&sprefix=trs+1%2F4+jack+to+2x+xlr%2Caps%2C203&sr=8-18
https://www.amazon.com/Tisino-Stereo-Y-Splitter-Return-Insert/dp/B07K59P692/ref=sr_1_1_sspa?crid=3OP43XXXORVQB&keywords=TRS%2B1%2F4%2BJack%2Bto%2B2X%2B1%2F4%2BTR&qid=1663713999&sprefix=trs%2B1%2F4%2Bjack%2Bto%2B2x%2B1%2F4%2Bt%2Caps%2C175&sr=8-1-spons&th=1
Finally after having gone through all this, I am confused by your comment:
“I split my signal using a IR to the send out to my mixer but want to go stereo.”
An example of your preset would help here, because it is not very clear what you want to direct out of the Sends.
The audio signal that leaves you regular outputs is stereo (unless you have a final block which collapses the signal to mono?). If you want to route the output of the parallel path which contains the IR from the Send socket, it will be mono (there is no stereo IR) unless it later passes through a stereo FX block.
Hope this helps/makes sense - because now, I’m confused.
  • Thanks 2
On 9/20/2022 at 4:04 PM, datacommando said:
For example:
Some examples:
Yes; i want to route the output of the parallel path, with an IR and a stereo reverb after it.
so, trs stereo to 2x xlr into my mixer at the xlr inputs
its a HX stomp by the way,
thanks!
  • Thanks 1
thanks!
That should do it!
Sorry hope this isnt throwing confusion into a easy question...:)
All potentially correct, but a bit unclear if you are using Send or Output. HX Stomp output are L/R TRS balanced, but send jack is TRS unbalanced since it's just a single output port.
If you are using the Send you can just go with a standard Y splitter cable (all 1/4" jacks) TRS to TS/TS, or a male TRS to two female TS, and then use two standard instrument cables to go into mixer.
If you use the main ouput, then you are doing good with two TRS 1/4" to XLR cables.
Yes im using the "Send", but the mixer only takes XLR
The main outputs go to a stereo amp and 2 guitar cabs.
Ok. So it's indeed a Y TRS splitter going into *2 TS to XLR (unbalanced cables).
All good. :]
