leonardoborges Posted October 26, 2022 Share Posted October 26, 2022 Hi there, I'm configuring a number of presets so that the main signal comes out of the helix 1/4" output but then I have an IR going out to an XLR. The preset below shows one of these: So very simple in this case. However, I have another patch where I have a poly shift and an Amp blend. Because the Poly takes so much DSP, I had to put the amp blend on the bottom path. But because of that, it doesn't seem I can then have the IR be sent to XLR as it seems we can only have on mixer and not have the path go back in and out again: So it seems that I have to choose in this case. Or I could put a "Send 1" block before the IR and have that go to the power amp. However if I do that, I would have to change every preset I have to work that way, which would be less than ideal. Is there a different way of routing this preset that would accomplish what I'm trying to do? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 27, 2022 Share Posted October 27, 2022 With all of the amp choices in Helix, you can't find an amp which, maybe with a bit of EQ, comes close enough to the "amp blend" to make it work? If not, you're either getting an external IR loader of changing a lot of presets to accommodate a few. Quote Link to comment Share on other sites More sharing options...
waymda Posted October 27, 2022 Share Posted October 27, 2022 Or you could use send block(s) for 1/4 inch output with 100% pass-through to the IR and make out XLR only. If you use this consistently across patches you just need ot remember what to plug your power amp to. 3 Quote Link to comment Share on other sites More sharing options...
leonardoborges Posted October 27, 2022 Author Share Posted October 27, 2022 @waymda ah that's an excellent point! A bit of work to change current patches to that model, but then it gives me all flexibility I need. Thanks for the suggestion! 1 Quote Link to comment Share on other sites More sharing options...
