Giffe61 Posted November 13, 2022 Share Posted November 13, 2022 Anybody can help? There‘s no looper in the preset. Actually I can see the name of the assigned effect for a short time after pressing the footswitch, but then the label switches back to the looper command, e.g. „undo“. How would I fix that and have the labels show the assigned effects only? Thx, Giffe Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 14, 2022 Share Posted November 14, 2022 On 11/13/2022 at 12:51 AM, Giffe61 said: Anybody can help? There‘s no looper in the preset. Actually I can see the name of the assigned effect for a short time after pressing the footswitch, but then the label switches back to the looper command, e.g. „undo“. How would I fix that and have the labels show the assigned effects only? Thx, Giffe Hi, Giffe, When weird and unexpected behaviour happens with your device, the first thing to try is a factory reset. (Make sure you have a backup of all your presets, etc., before doing this) HX Effects Button Combination Description Holding FS3 + MODE Will clear all Presets and IRs Holding FS4+FS5 Will reset Global Settings Holding FS5+FS6 Will reset Presets only Holding FS6+TAP Will Perform factory restore (reset, Globals, IRs, and Presets) Holding the right arrow ">" Will put the unit in a fail safe update mode. Use this when the HX Effects is in an un-recoverable state To use Reset Options: Power off the Helix Hold the desired button combination Power on the Helix Release the button combination If this doesn’t clear the glitch, try a reinstall of the latest firmware. Still no success? Contact Customer Support. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
Giffe61 Posted November 15, 2022 Author Share Posted November 15, 2022 Thx, resetting the presets helped already! 1 Quote Link to comment Share on other sites More sharing options...
