Best Impulse Response Cabs for Pod Go
louisjsvitekjr
Do the amp model packs you purchased also include IRs? Some do, some don’t. If they do include IRs these will be separate files in the amp model download package that you need to manually import into the POD Go’s IR library. If IRs are not included then you select one of the existing POD Go cab models to use along with the purchased amp models.
Yeah, also it's not possible to add 'cabs', cabs are PGO only.  But you can add IR, which will appear under the IRs section, but its name might not be exactly what you expect (ex; amp name), it might have a more technical name, think it uses the IR filename as the name of the IR once imported.
And the Best IR is still The Best IR In The World.  ;)
