ValiantGideon Posted May 26, 2013 Share Posted May 26, 2013 More specific to my needs, is it not possible to simply plug an XLR cable from a separate powered speaker to the out jacks of the L3M while connected through L6 Link. A more broad question would be, is the speaker just not able to use other I/O jacks while L6 Link is being used? Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted May 27, 2013 Share Posted May 27, 2013 The Mix Out always carries all input signals and all inputs work simultaneously. So- yes it is possible and yes the speaker is able to use other I/O while L6 Link is being used. Quote Link to comment Share on other sites More sharing options...
ValiantGideon Posted May 27, 2013 Author Share Posted May 27, 2013 The Mix Out always carries all input signals and all inputs work simultaneously. So- yes it is possible and yes the speaker is able to use other I/O while L6 Link is being used. Is the "Mix Out (All Inputs)" an amplified signal? Basically with the whole system (2 L3M's and 2 L3S's) running through L6 Link I then wanted to plug a single passive monitor into the "Mix Out" with an XLR plug. After plugging it in I was met with absolutely no sound coming through the monitor (not even a whisper with my ear as close as could be). Unless I'm missing something there is no sound coming through the "Mix Out" plug to my monitor. Keep in mind that I am very aware of the 4 monitor outputs on the StageScape but our group uses the Aviom system and we have no need for those. Using those provided outputs would still not solve the problem of the signal not being amplified through the passive monitor. Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 27, 2013 Share Posted May 27, 2013 Is the "Mix Out (All Inputs)" an amplified signal? It is line level and meant to drive an amplified speaker. It will not drive a passive speaker. Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted May 27, 2013 Share Posted May 27, 2013 In fact none of the outputs on the M20d are amplified. As with any non-powered board you need to use either powered speakers or passive with a power amp in between. Just as you wouldn't use your L3m or L3s speakers with a powered board. Quote Link to comment Share on other sites More sharing options...
