helix with studio monitors
cfitch13
I currently have my helix connected to 2 Yamaha HS7 studio monitors.  I would like to try and incorporate my headstrong as a center speaker on the floor. I connected it thru the 1/4 jack and it plays fine with the system. Is there a way for me to cut some of the highs out of just that speaker.
Global EQ can be applied to 1/4" and XLR, but not either/or.
Using an EQ block in a split path you can use the XLR Outs at the end of one and a 1/4" (with the L/Mono Out) at the end of the other.
An interesting use of the HR and HS7s is to use the HR as the dry component of a WDW configuration by placing a SEND between the PRE and POST amp FX like this:
Guitar>Helix Input>OD/Dist/Mod>Amp>SEND (to HR)>Mod/Delay/Reverb>XLR to HS7
  • Thanks 1
Actually, they can be either/or :)
From page 63 (Global EQ section) of the manual....
"Global EQ is applied to all setlists and presets and can be heard from the 1/4" outputs, XLR outputs, or both."
I keep mine set to XLR outs which is my FRFR. The 1/4" outs go to a DI prior to heading to the FOH/Monitors.
On 1/5/2023 at 1:09 AM, cfitch13 said:
I found where you could apply EQ to 1/4 outputs only.
That's the answer!
  • Thanks 1
On 1/5/2023 at 12:58 PM, rd2rk said:
I'm having a bad week...
We all have bad weeks.. New to the guitar world and appreciate everyone that takes time out of there day to help.  Thanks for help, Ill give these all a try.
