tuner not working after upgrade?
kjbllc123
On 1/14/2023 at 10:39 PM, kjbllc123 said:
wondering if anyone else has had this problem.
You didn’t say what hardware you are using, but nope, everything as it should be on my Helix Floor in all three modes.
On 1/14/2023 at 4:39 PM, kjbllc123 said:
everything else working fine but the tuner is not , does not seem to be getting signal, but the input is at max. wondering if anyone else has had this problem. thanks.
No problem here after the update. Have you opened the tuner settings to see what the INPUT is set to? Maybe it was inadvertently set to one of the returns instead of the guitar input?
When you updated did you follow all procedures, including the process of "backup > factory reset > restore".
Global settings are often changed during an update... it is imperative (at minimum) to restore the global settings which includes the tuner settings.
