kjbllc123 Posted January 14, 2023 Share Posted January 14, 2023 everything else working fine but the tuner is not , does not seem to be getting signal, but the input is at max. wondering if anyone else has had this problem. thanks. Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted January 14, 2023 Share Posted January 14, 2023 Nope. Only thing I noticed is that it seems to be a little jumpier but I think that may have happened in 3.1. Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 14, 2023 Share Posted January 14, 2023 On 1/14/2023 at 10:39 PM, kjbllc123 said: wondering if anyone else has had this problem. You didn’t say what hardware you are using, but nope, everything as it should be on my Helix Floor in all three modes. Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 15, 2023 Share Posted January 15, 2023 On 1/14/2023 at 4:39 PM, kjbllc123 said: everything else working fine but the tuner is not , does not seem to be getting signal, but the input is at max. wondering if anyone else has had this problem. thanks. No problem here after the update. Have you opened the tuner settings to see what the INPUT is set to? Maybe it was inadvertently set to one of the returns instead of the guitar input? When you updated did you follow all procedures, including the process of "backup > factory reset > restore". Global settings are often changed during an update... it is imperative (at minimum) to restore the global settings which includes the tuner settings. Quote Link to comment Share on other sites More sharing options...
theElevators Posted January 16, 2023 Share Posted January 16, 2023 Or..... you can just go into the tuner, and press every single knob--that way they will reset to the factory settings. Quote Link to comment Share on other sites More sharing options...
