HX stomp doubling MIDI clock input?
mtumi
Found a post that led me to a resolution, although i don't follow logically why turning off Tx MIDI Clock should fix it.  unless it is two different sets of clock going out - one thru from the chain and another generated by the HX stomp itself.  I guess that would make sense.
In any event turning off Tx MIDI Clock seems to have fixed it
Yes, you wouldn't want to have the Stomp sending its own MIDI clock signal if it's already passing the signal from the other pedal through.
