Jonnymuck Posted March 7 Share Posted March 7 Hi, I recently just went to remove my headphone plug from the HX stomp headphone jack and half of the plug broke off inside the jack. Is there anyway to get this removed without having to take to the service center? From looking at pictures of the underside of the HX stomp. The circuit board would have to be removed to get access to the top of the headphone jack. Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted March 8 Share Posted March 8 I don't see how it could be done from the outside. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted March 8 Share Posted March 8 On 3/7/2023 at 9:01 PM, Jonnymuck said: half of the plug broke off inside the jack You mean the tip? It should be hollow, so you can try to pull it out with long thin pliers, or by using a long screw, or a wire with a hook at the end, possibly also using some glue or adhesive tape to fix it to the tip. That said, sometimes it's actually easier to open things up… 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 8 Share Posted March 8 On 3/7/2023 at 8:01 PM, Jonnymuck said: I recently just went to remove my headphone plug from the HX stomp headphone jack and half of the plug broke off inside the jack. Is there anyway to get this removed without having to take to the service center? Hi, Try this:- Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
