juanreed Posted April 24 Share Posted April 24 Can the HX Effects be configured to start effects types that involve "movement" (such as sweeps, ramp up/down, etc.), like the Throbber filter, from the beginning position each time the effect is turned on or when changing snapshots/presets? Quote Link to comment Share on other sites More sharing options...
brue58ski Posted April 24 Share Posted April 24 It does have MIDI in and out if that will work. My understanding is it is limited. I've never used it. Quote Link to comment Share on other sites More sharing options...
theElevators Posted April 24 Share Posted April 24 On 4/24/2023 at 8:51 AM, juanreed said: Can the HX Effects be configured to start effects types that involve "movement" (such as sweeps, ramp up/down, etc.), like the Throbber filter, from the beginning position each time the effect is turned on or when changing snapshots/presets? No! No such thing. It'll keep oscillating at a constant speed, unless you use some trickery with the expression pedal to change the rate. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted April 24 Share Posted April 24 On 4/24/2023 at 4:10 PM, theElevators said: No! No such thing. It'll keep oscillating at a constant speed, unless you use some trickery with the expression pedal to change the rate. Maybe some fancy programming on the sweep/bypass state could get you close using an auto engage approach and the sweep Quote Link to comment Share on other sites More sharing options...
craiganderton Posted April 24 Share Posted April 24 On 4/24/2023 at 4:10 PM, theElevators said: No! No such thing. It'll keep oscillating at a constant speed, unless you use some trickery with the expression pedal to change the rate. In theory, there's a MIDI command that will reset a pattern IIRC. You can also reset patterns by tapping the tempo switch, but then the tightness of the sync depends on you, not a MIDI command. I think I'll look into this further, as well as with respect to Helix Native. 1 Quote Link to comment Share on other sites More sharing options...
