I am wondering whether it is possible
juanreed
On 4/24/2023 at 8:51 AM, juanreed said:
Can the HX Effects be configured to start effects types that involve "movement" (such as sweeps, ramp up/down, etc.), like the Throbber filter, from the beginning position each time the effect is turned on or when changing snapshots/presets?
No!  No such thing.  It'll keep oscillating at a constant speed, unless you use some trickery with the expression pedal to change the rate.
Maybe some fancy programming on the sweep/bypass state could get you close using an auto engage approach and the sweep
In theory, there's a MIDI command that will reset a pattern IIRC. You can also reset patterns by tapping the tempo switch, but then the tightness of the sync depends on you, not a MIDI command.
I think I'll look into this further, as well as with respect to Helix Native.
  • Thanks 1
