YaketyAxe Posted May 24, 2023 Share Posted May 24, 2023 Hi, I'm new to the podgo, I have the wireless version. I noticed after downloading a preset from Customtone, it doesn't have the Footswitch block. I thought that block was mandatory on the chain. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 24, 2023 Share Posted May 24, 2023 There is no Footswitch block. Do you mean the Vol or Wah (pedal) block? Or maybe the FX Loop block? Quote Link to comment Share on other sites More sharing options...
YaketyAxe Posted May 24, 2023 Author Share Posted May 24, 2023 On 5/24/2023 at 9:47 PM, silverhead said: There is no Footswitch block. Do you mean the Vol or Wah (pedal) block? Or maybe the FX Loop block? Volume pedal block on Podgo wireless,made by line 6 Quote Link to comment Share on other sites More sharing options...
voxman55 Posted May 24, 2023 Share Posted May 24, 2023 Are you sure its not showing in the display but just not turned on or not assigned to the expression pedal? If it's physically missing in the Pod Go display i.e, there is no volume and/or wah icon in the display, the patch you've loaded down could be a modified patch to give more than 4 user blocks with the volume and or wah pedals removed to make way for additional blocks? (did the patch have any text explaining this?). A modified patch is perfectly safe to use, these don't void warranties, they cannot damage your Pod Go, and cannot affect other patches. A modified patch is just where the JSON script code in the patch file has been modified (you can learn all about these patches on the internet and forums - sometimes unkindly called 'jail-break' patches). Quote Link to comment Share on other sites More sharing options...
YaketyAxe Posted May 24, 2023 Author Share Posted May 24, 2023 Thanks @voxman55 Yes it's not greyed out, it's definitely not there, and nother preset also has both wah and volume pedal blocks missing. I was I guess just curious, strangely enough the 2 presets which have these blocks missing are my best sounding presets, coincidence I know....or can't think of a valid reason why they should be, given I never have these 2 blocks enabled when they are there. Quote Link to comment Share on other sites More sharing options...
