Ebusje Posted August 31 Share Posted August 31 I have a powercab which is obviously an active cabinet. I also have a small tube amp head, which I want to connect to the same speaker. I'm not going to connect my amp to the powercab 1/4 inch plug, because my amp needs a direct load to a speaker. Can I connect a passive speaker wiring harness to the same speaker, with a separate 1/4 inch plug ? So if I want use my Helix, I will connect it to the Powercab input, but if I want to use my amp, I will connect it to the installed wiring harness 1/4 plug, with the Powercab turned off. Maybe not a smart idea, but is this possible to do ? Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted August 31 Share Posted August 31 Depends on whether you can impedance match the amp and speaker. Of course, you'd have to open the PC up to try it. Quote Link to comment Share on other sites More sharing options...
