HAMERMAN409 Posted September 6 Share Posted September 6 Is there a way to assign a footswitch so that the effect is only enabled while the footswitch is being pressed (and then turns back off when the footswitch is released)? Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 6 Share Posted September 6 No. 1 Quote Link to comment Share on other sites More sharing options...
HAMERMAN409 Posted September 7 Author Share Posted September 7 OK - thanks for confirming. Would be a nice feature to add in the future since it probably wouldn't require additional DSP or anything like that. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted September 7 Share Posted September 7 On 9/6/2023 at 3:28 PM, silverhead said: No. Just an idly curious & probably silly thought here Silverhead, but Pod Go has been designed to accept external momentary footswitches to perform as latching footswitches (I use two with mine for FS7/8). So I was just wondering what would happen if you connected a latching foot-switch (I don't have one to try) - would it (a) behave the same as a momentary (in which case why would you need a momentary switch?) (b) not work or work unreliably/oddly, or (c) act in reverse like a momentary switch? Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 7 Share Posted September 7 Here’s a snip from the manual pg 7 discussing the rear panel hardware I/O, confirming your note re: design. I suspect your answer is (b) but like you I can’t test it. For external footswitches, the momentary (unlatched) type should be used. Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 14 Share Posted September 14 You can assign effects to the expression pedal 1/2. Bypass/un-bypass blocks either immediately or after up to 1 second. Quote Link to comment Share on other sites More sharing options...
