HELP! 4CM with 5150 Iconic 40w Combo
Stephenasaurus
Apologies if this has been asked before but i'm pulling my hair out trying to sort this and I have a gig tonight!
I recently purchased a 5150 combo which i love, however i'm having issues running the Helix LT through the effects loop. I have followed a number of videos on youtube, none of which seem to mention my problem nor solve it. I'll be as brief as a can...
Basically, I think I am only hearing the effects loop most of the time. Its a clean signal. I can get the amps drive channels to work, but I also hear a clean signal over the top of it. Then if i use the delay in the loop, it just delays a clean signal? I have no idea what I've done wrong as the 4cm is set up exactly as the video suggests.
In terms of the patch I have tried using the effects loop block as well as the send/return blocks. I still have the same problem. Just wondering if anyone has a quick fix?
I should also mention that as soon as a plug any cables into the 5150 it cuts the sound from the instrument input. Is this normal?? I have also tried using the preamp out from the 5150 but this hasn't had any effect.
Currently at work, so I cant try out anything for a few hours but I'd be very grateful for some help!
Evh 5150 Iconic 40W 1x12 Combo IV – Thomann UK
Videos ive tried:
Helix Minute: 4-Cable Method - YouTube
How to do the 4 cable method with the Line 6 Helix (the EASY way!) - YouTube
One last thing - I had a blackstar head and 2x12 cab before this 5150, set up the exact same way. I used the midi in the to switch channels as an addition to the 4cm. I never had any issues with the exact same setup im trying to use now.
  • Stephenasaurus changed the title to HELP! 4CM with 5150 Iconic 40w Combo
Do you have an FX Loop Block in the signal chain?
Are you using the matching S/R jacks?
Are you using the amp's S/R jacks, NOT the "Pre Out"?
If you jumper the S/R jacks on the amp, are you still getting sound?
Are you SURE all of your cables are good?
Proper wiring using FX Loop 1 Block in signal chain:
Guitar>Helix Input>Helix Send 1>Amp Input>Amp Send>Helix Return 1>Helix L/MONO Output>Amp Return
EDIT: If you're using separate SEND and RETURN Blocks as some YT wizards suggest, is the "Dry Thru" on the SEND Block set to -120db?
If not, that could explain the added "clean" signal you hear.
The MIX on the RETURN Block should be 100%.
