flynnnolan Posted April 4, 2014 Share Posted April 4, 2014 I have a wireless hd v75 handheld mic with receiver. I can't get audio out of it for the life of me. Both set on the same channels, plenty of battery, Mute on transmitter is OFF, both have encryption off and name off. Have unplugged and powered on/off a few times. As you can see in the picture it's showing that it's receiving signal but the mute button stays red like that. Can someone please help me as to what is going on here? The last time I used the mic there was some distortion feedback coming through my system so I'm wondering if it is a dropout. If so what do I have to do reset it somehow? Quote Link to comment Share on other sites More sharing options...
dboomer Posted April 4, 2014 Share Posted April 4, 2014 You don't by chance have the lockout switch on the transmitter turned on do you. Quote Link to comment Share on other sites More sharing options...
flynnnolan Posted April 4, 2014 Author Share Posted April 4, 2014 is that the button on the inside of the microphone behind the batteries ? If so, then no…it was on the unlocked side... Quote Link to comment Share on other sites More sharing options...
flynnnolan Posted April 4, 2014 Author Share Posted April 4, 2014 if you go into the other thread i attached a photo. Quote Link to comment Share on other sites More sharing options...
Solong Posted August 31, 2018 Share Posted August 31, 2018 Was there ever a solution to this problem? - I have the same thing, Handheld mic is working (tested on another system) but XD-V75 ALWAYS has the mute led lit when the transmitter is turned on and unmuted. Quote Link to comment Share on other sites More sharing options...
Hyesteve Posted October 20, 2019 Share Posted October 20, 2019 I have the same problem. Mute is off on the mic but mute is on at the receiver. Quote Link to comment Share on other sites More sharing options...
chrisRA Posted December 11, 2021 Share Posted December 11, 2021 Anyone ever figure this out? My receiver is also stuck on mute. All firmware is updated, mic isn't locked, what gives? thx for any insight ;) Quote Link to comment Share on other sites More sharing options...
Sheriton Posted December 16, 2021 Share Posted December 16, 2021 A slight clarification - the mute LED on the receiver indicates that the transmitter is muted (or at least that the receiver believes that the transmitter is muted.) The receiver itself has no mute function so there's no way of unmuting it. All I can think of is to triple check that the transmitter isn't locked (which would prevent its mute button from working) and also to check firmware versions. I don't know if there's any compatibility issues between different versions (there shouldn't be!) but it's good housekeeping to keep them both current. Try switching between RF1 and RF2 modes as well if you can - no reason why that should affect this but you never know. One final thought - it's conceivable that if there's huge amount of RF interference present, the receiver may give up trying to operate and stay silent (clutching at straws here) - do the RF lights show any signal with the transmitter switched off? Also try a different channel. Quote Link to comment Share on other sites More sharing options...
Solong Posted June 6, 2022 Share Posted June 6, 2022 Tried everything I can think of - transmitter not on mute (works well with other receivers) tried all channels. Mic is within 1 foot of receiver. As soon as mic switched on, Rx shows good RF (5 leds), good battery (new batteries and 5 leds), Audio moved when mic used, MUTE led lit - no Tx output. Rx firmware is the latest (2.04). Exactly the same results with TBP12 and TBP 6 transmitters. Mic works perfectly into RSX-06 receivers. Basically, the XD-V75 is an expensive paper-weight. I'm starting to lose trust in Line 6 products Quote Link to comment Share on other sites More sharing options...
Solong Posted June 6, 2022 Share Posted June 6, 2022 I should add that I have 2 of these XD-V75 receivers both with exactly the same symptoms. I also have a Variax 600 which is no longer supported and a Floor POD XT with a duff display which apparently cannot be repaired. Doesn't say a lot for Line 6, does it? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 6, 2022 Share Posted June 6, 2022 On 6/6/2022 at 5:03 AM, Solong said: Tried everything I can think of….. Have you opened a support ticket? Quote Link to comment Share on other sites More sharing options...
ashleighbryant Posted February 23, 2023 Share Posted February 23, 2023 Is there a solution to this yet? My XD-75 just started to do the same thing! Quote Link to comment Share on other sites More sharing options...
